7 members (TexasJim50, DadsFirstPickup, 54farmtruck, Patharr, klhansen, Pete1946, 1955 1 Series), 114 guests, and 4 robots.
Topics128,148
Posts1,056,811
Members48,454
#734699 03/30/2011 5:06 PM
Working on my 41 and the clutch and brake pedals are almost complety smooth from use. Are there any rubber covers for them or any other way to restore other than build up with weld and resurface? Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Ex Hall Monitor
Ex Hall Monitor
About all the vendors sell rubber pads.
Chevs of the 40s.
The Filling Station
All the suppliers sell them, but do any sell pads that stay on?
For the prewar and deco trucks, many were designed for use without rubber. If your pedals are in rough shape, they pop up on fee bay all the time.
I am using a set of big truck pedals for my 1940. The big trucks used a frame mounted master cylinder. The pedals still bolt to the bellhousing, but the master cylinder is bolted to the frame. I figured this would be easier to manipulate when I install the new MC for the disc brakes. It gives me plenty of clearance for my transmission.
If they are that worn I would and probably will anyway, get one pad from a vendor, cast a mold of the face and depth of it, then cast a new pad right to the pedal. I use Hapco Inc. products. You will always have the mold and probably never wear out the ones you cast.
1937 Chevy 1/2-Ton
Ter Offline
Great set of photos. You are doing a great job!
Am interested in the product you mentioned above Hapco Inc. Do you make a mold of your parts with one of their products and then use another product as the casting material? Are there some instructions on the web you can suggest?
Ter
