6 members (68ironhead, Ridgeback, Phak1, Joe H, Tinker5, GMCJammer51), 74 guests, and 0 robots.
Topics128,196
Posts1,057,398
Members48,471
Im pretty sure all Rochester 1BBl carbs are basically the same on the 1950's 216 and 235 engines, but I would like to confirm that my kit is right before I open it up!
Its an 'Auto-Tune Engine Performance parts' By BWD Automotive Corporation.
The part # is 15157. It also came with an intruction sheet for Rochester Models "B", "BC", and "BV".
Im pretty sure my 1951 with a 216 has the Rochester model B. It does not really need a rebuild, but it does not run a smoothly as the 59 does (which my dad put a reman carb on). And I just want to get some more experience working on carbs, this will be my first rebuild!
Austin
1951 1/2 Ton 216ci 4spd
1955 3/4 Ton NAPCO 235ci 4spd
1959 1/2 Ton stepside 235ci 4spd
The carb kits I have used come with optional gaskets. Just look close and match with the old ones, especially the cover gasket.
My Blog
