1 members (baldeagle),
89
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 53 | The wipers for my truck have one control yet there are two openings in the overhead dash. What is the second opening for? | | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | This is mine from the 37, seems to be missing something on the right hand dial side (suspect speed control), the left is a pull in and out action (probably on and off) will be sending it to the wiperman to rebuild. I can not remember how my 49 4rd vac wipers worked,its been many years, but it was not good I definitely remember that. Hope that helps with a visual. I am sure some one who is not a night owl will post in the a.m. My interior panel has two holes that the two controls poke thru. [IMG] http://i111.photobucket.com/albums/n142/DCINSC/37%20CHEVY%20REBUILD/DSCF4070.jpg[/IMG]
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | That's correct. The push-pull is on-off and the other knob is a speed control. It turns although I can't remember in which direction as I haven't used mine in years.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Feb 2011 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 53 | I guess mine is just a single speed because there isn't anything attached to the right side of the wiper. | | |
