0 members (),
38
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 86 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 86 | Is there a spacer between the frame and the cross rails in the bottom of the bed? I need to fasten the bed back down and want to do it rite the first time. thanks
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I think your 39 may be like the 37's. Yes, ther is a spacer. I believe the blocks of wood are 2 1/4" X 2 1/4". someone will have to verify that. And put a little piece of rubber between the chassis and the wood.
Note, I seen where someone had the ida to use plastic blocks...just an idea to consider. | | | | | Joined: Feb 2010 Posts: 86 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 86 | Thanks chipmunk. That 37 you have is number 1 !!! | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | As Alvin says, wood blocks with a 1/4" thick spacer between wood & steel. I used a high density industrial plastic material rather than rubber. | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | The 37-39 Short Step had 6 blocks - 4 small blocks and 2 large ones. The kits we sell also include 6 rubber pads 1/4" thick. Hope this helps. | | | | | Joined: Feb 2010 Posts: 86 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 86 | | | |
