5 members (Bill Hanlon, Gdads51, 50Chevy3100, Charles in CA, 1 invisible), 59 guests, and 6 robots.
Topics128,095
Posts1,056,078
Members48,433
#733772 03/28/2011 12:09 AM
Is there a spacer between the frame and the cross rails in the bottom of the bed? I need to fasten the bed back down and want to do it rite the first time. thanks
I think your 39 may be like the 37's. Yes, ther is a spacer. I believe the blocks of wood are 2 1/4" X 2 1/4". someone will have to verify that. And put a little piece of rubber between the chassis and the wood.
Note, I seen where someone had the ida to use plastic blocks...just an idea to consider.
Thanks chipmunk. That 37 you have is number 1 !!!
As Alvin says, wood blocks with a 1/4" thick spacer between wood & steel. I used a high density industrial plastic material rather than rubber.
1940 Chevy KC 1/2-Ton
The 37-39 Short Step had 6 blocks - 4 small blocks and 2 large ones. The kits we sell also include 6 rubber pads 1/4" thick.
Hope this helps.
thanks everyone lug
