1 members (NofoolN),
125
Mod | | | Forums66 Topics128,186 Posts1,057,317 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 7 New Guy | | New Guy Joined: Jan 2011 Posts: 7 | what starter motor is for a 54 chevy hydra-matic? Mine grinds teeth on a perfect flywheel, must be wrong. - Anthony
| | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | Your starter may be ok but have the incorrect starter drive in it. Hit your local auto parts store and see what they can do for you. Around here, they act like someone superglued their elbows to the counter when I mention needing parts for a 54 model. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Could also be the drive itself is slipping inside since you say the teeth are okay. Wouldn't take much grinding to show up on the teeth. But when the drive slips inside it can sound like it is grinding. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Greg, the drives on a mechanical engage starter won't interchange between 6 and 12V starters. Do you know they will on these starters?
Bastieri, according to my Hollander manual, a '49-'55 truck starter can be used by switching the drive housing and installing the solenoid.
| | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | Cletis, I don't know that. I just thought that there was a chance that the tooth count was the only real difference other than the armature but it makes sense that the armatures could have different shaft diameteres which would make the drives not interchangable. Thanks for the other interchange info though. | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy Bastieri and guys, the o.e.m. p/n for the automatic starter in 1954/55A series is 1814232, all six volt starters from 1941 - 55 use the same starter drive, according to my parts book. | | | | | Joined: Jan 2011 Posts: 7 New Guy | | New Guy Joined: Jan 2011 Posts: 7 | OK, I need to put the word out that I need to buy this. Anyone using one as a door stop? o.e.m. p/n for the automatic starter in 1954/55A series is 1814232
| | | | | Joined: Jan 2009 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 101 | Finding one of these starters (complete) for the 54 Hydra-matic is like finding a needle in a haystack. The starter is different size than others made for the same trucks with manual transmissions. I know, I had to shop for one a few years back. Took me six months to find a complete working starter.
Disciple
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Place a Want Ad in the Swap Meet
| | | | | Joined: Jan 2009 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 101 | Hey, just wondering if you ever found a extra starter for the hydra-matic. I am again looking. Thinking that you may have found a source and know where one might be available. Ted
Disciple
