Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Peggy M, 2-Ton, Jon G, Wickedbass, tclederman, Youngin' Tut 59), 42 guests, and 7 robots.
Topics128,010
Posts1,055,303
Members48,419
#73290 02/15/2007 7:09 PM
hi all , i have a 55 - 235 truck engine . i ordered a carter yf 2100 & recieved it in a bubble pack . the problem is it is a size #2 , i need a size #3 ( wider stud spacing ). my napa man is having problems finding this carb . ( i want to keep the hand choke ).
any suggestions ? thanks in advance : ) frank
#73291 02/15/2007 8:11 PM
When looking for a replacement for my Carter YF I found a Single Barrel Holley at a local parts store. It had a wider spacing, although I couldn't tell you how much wider.
In the end I got the Carter rebuilt.
If it ain't broke, take it apart and figure out why!
39 Chevy in the Gallery
Photobucket Album
#73292 02/15/2007 8:27 PM
problem is i have a rogester that's bad - realy gummed up . i've read so many good posts about the carter yf & want to upgrade . thanks
#73293 02/15/2007 9:05 PM
Carburetion specialist
2100s, as built by Carter, IS a size 3. Sounds like yours has been subjected to "hanky-panky".
Jon.
The Carburetor Shop
#73294 02/16/2007 9:12 AM
if it dosent have to be much wider take a round file and make the holes slots the metal is soft works good
#73295 02/16/2007 1:02 PM
thanks 39az , i have a buddy in sunny tucson .
thanks carbking - also for your time in talking to me ! i appreciate it .
32fire2 about 1/4 inch difference - that would be a lot of filing on the mount . & then there's the carb throat - i don't think it is thick enough for that . & thanks . frank
#73296 02/16/2007 2:03 PM
The manual choke carbs are a lot tougher to find than the auto choke carbs. I believe this to be because of those using dual and triple carbs want the manual choke versions.
If you don't mind an automatic choke (I don't personally like them myself); it is relatively easy to install an automatic choke carb replacing a manual choke. The only issue is the heat for the choke. That may be provided as follows:
1) acquire a piece of roughly 18 gauge sheet metal 6 inches by 3 inches
2) cut a 1/2 inch square from each corner
3) bend the 4 sides, making a rectangular "cup" of depth 1/2 inch
4) drill a hole in the center of the cup and install a brass fitting
5) install the cup on the exhaust manifold with the open end toward the manifold
6) bend a piece of tubing to attach to the brass fitting and the carburetor choke
Jon.
The Carburetor Shop
#73297 02/19/2007 7:31 PM
DW Offline
The difference between a #2 and #3 is more than just the spacing of the studs. The bottom "bore" size is also different (I also just received a #2 "YF2100" from Jim Carter).
Carbking, would there be a performance (horsepower, gas mileage) different between these two carbs on the same 235 in a 3100?
Dave
#73298 02/19/2007 10:26 PM
carbking , can you give us another option ( brand ) of carburetor to look for ?
seems the carter yf 2100 #3 is unattainable !
thanks frank
#73299 02/20/2007 1:47 AM
Frank,
When I was looking to find a replacement, I found alleged NOS Carter YFs online for about $240.00 a piece. It may be worth doing a search and asking on the stud spacing.
In general, single barrel carbs are very difficult to find these days. I even went to the local speed shop and they couldn't get anything less than a 2bbl.
Again, I found a Holley that might work out through a local Autozone. It was too wide for my stud spacing.
Good luck. I am, for obvious reasons, a bit biased when it comes to 39 trucks.
Photobucket Album
