4 members (Hanks custodian, klhansen, Peggy M, 1 invisible), 123 guests, and 2 robots.
Topics128,052
Posts1,055,727
#731966 03/21/2011 10:42 PM
1 Offline
all of the little lights that go behind the gauges in my truck are gone, what size lights or part number do i need and how many?
1 Offline
1952 Chevrolet 1/2ton converted to 12volt
You need 6 or 7:
Two for the gauges.
Two for speedo/one for the Brights.
One for the ignition switch cover.
One more for the glovebox if it has a light.
I use Sylvania 55 other makes will work as well they have two prongs at the same elevation those are the type you need.
I have a chart that I copied from somewhere(?) that shows 6v and 12v bulbs for Chevrolet vehicles 1954-57. The title of the chart is "A Time Saving Bulb Chart to Help You." Can anyone supply the link? I won't post the chart because PhotoBucket will lower the resolution and make the chart unreadable, however I can email the chart to you.
Especially good for 6v trucks that have been converted to 12v.
- Lonnie
- Lonnie
My '54 3104
LonnieC #732033 03/22/2011 2:14 AM
That's it. I looked on your site before posting, but didn't find the chart. I have put it to good use a number of times for my '54 converted to 12v.
- Lonnie
- Lonnie
My '54 3104
LonnieC #732098 03/22/2011 5:22 AM
Is there something like that for '51's and '52's OR are they all the same?
The CPA, never under estimate the value;
especially when he's driving an old Chevy truck!
1947 Chevy 1/2-Ton Advance Design in the Gallery
1951 Chevrolet 3100
