Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (jmoore, frogfarmer, Jon G), 105 guests, and 4 robots.
Topics128,288
Posts1,058,574
Members48,492
#730839 03/18/2011 1:19 AM
Hey guys, I'm about to swap pumpkins from a 57 3100 into a 54 3100. Have never done this before----any tips or secret?? How do the axles come out???
fixitguy #730847 03/18/2011 1:52 AM
One tip,
Always start with the service manual, best to read it the day before you plan on doing the work, and again as you work on it.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #731010 03/18/2011 4:22 PM
There are links here for the "Old Car Manual Project". Print the pages for the R&R of the rear and keep them with you in the shop.
Highflyer #731059 03/18/2011 8:00 PM
Achipmunk #731104 03/18/2011 10:57 PM
Thanks guys----you never let me down
fixitguy #731214 03/19/2011 6:49 AM
Does the 54 have a torque tube or is it open drive line ?
If it is a torque tube,you will need to set the pinion angle and weld up the pivot points.
Tim
1951 3100 Chevrolet
