3 members (Jon G, Guitplayer, Wally / Montana), 123 guests, and 4 robots.
Topics128,109
Posts1,056,269
Members48,439
#73047 02/11/2007 9:33 PM
Brought my neighbor Hank, down to assist me on starting up my newly rebuilt 261 on Saturday. His job was to watch all of the water, oil and fuel connections for leaks. After about 30 seconds of cranking, the old geezer started and varoooooom! Ran it for 20 minutes to break in the cam and then shut it down. Dual exhaust system sounded great although I had to take Hank's word for it as I was sitting in the cab. Two minor oil leaks around the newly installed filter. Can't wait to get the minor things fixed and get this truck back on the road!
http://community.webshots.com/user/geezer
Country Roads, West (By God) Virginia
#73048 02/12/2007 12:29 AM
Congrats....if it runs half as good as it looks you're the winner!!!! I'm a couple weeks behind you in my engine rebuild, and the anticipation is killing me!!!!!
Was curious about your oil pressure with the full-flow filter system? Got any suggestions as I'm following your footsteps on this process. (As well as several others)? Keep us posted!
Dave cool
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#73049 02/12/2007 1:13 AM
grin NICE!!! I like the stainless water and fuel lines. Good job.
#73050 02/12/2007 1:33 AM
Let me add my congratulations also Geezer. You've done a terrific job on that old girl. Looks great.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#73051 02/12/2007 7:07 AM
Looks sweet, I like the line work on the fuel system & the rest.
Do have a tip for ya if you haven't changed it already.
On the lines going behind the thermostat housing that you put pieces of hose around, ya might look at using rubber coated line clamps to keep them steady. Those ones aren't the best, just some heat shrink on a line clamp. The nicer ones that are pretty much like what we use in aircraft plumbing are Adel, neoprene cusioned line clamps . Now THOSE are the poo, I use them on any hardline project.
You can bolt a couple together to keep lines from rubbing (beats zip ties!), and/or use a bracket to affix long lines in place to prevent vibration.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
#73052 02/12/2007 7:04 PM
Fla54;
When the engine started up, my oil pressure went to 60 psi for a little while then settled out between 30 and 40 psi. Of course, new oil, filter and a tight engine. Will see how it does after I get a few hundred miles on it.
Freq;
Thanks for the tips. May just give them a try. Wasn't very happy with the tiewraps and hose but Hey, it works for now. Really wanted to use billet clamps but couldn't get them to fit the way I wanted.
