8 members (KEVINSKI, mick53, 55shaker, Peggy M, Gdads51, Hanks custodian, MickeyP, 1 invisible),
148
Mod | | | Forums66 Topics128,089 Posts1,056,137 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73047 02/11/2007 9:33 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Brought my neighbor Hank, down to assist me on starting up my newly rebuilt 261 on Saturday. His job was to watch all of the water, oil and fuel connections for leaks. After about 30 seconds of cranking, the old geezer started and varoooooom! Ran it for 20 minutes to break in the cam and then shut it down. Dual exhaust system sounded great although I had to take Hank's word for it as I was sitting in the cab. Two minor oil leaks around the newly installed filter. Can't wait to get the minor things fixed and get this truck back on the road! http://community.webshots.com/user/geezer | | |
#73048 02/12/2007 12:29 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Congrats....if it runs half as good as it looks you're the winner!!!! I'm a couple weeks behind you in my engine rebuild, and the anticipation is killing me!!!!! Was curious about your oil pressure with the full-flow filter system? Got any suggestions as I'm following your footsteps on this process. (As well as several others)? Keep us posted! Dave  | | |
#73049 02/12/2007 1:13 AM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 |  NICE!!! I like the stainless water and fuel lines. Good job. | | |
#73050 02/12/2007 1:33 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Let me add my congratulations also Geezer. You've done a terrific job on that old girl. Looks great. | | |
#73051 02/12/2007 7:07 AM | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | Looks sweet, I like the line work on the fuel system & the rest. Do have a tip for ya if you haven't changed it already. On the lines going behind the thermostat housing that you put pieces of hose around, ya might look at using rubber coated line clamps to keep them steady. Those ones aren't the best, just some heat shrink on a line clamp. The nicer ones that are pretty much like what we use in aircraft plumbing are Adel, neoprene cusioned line clamps . Now THOSE are the poo, I use them on any hardline project. You can bolt a couple together to keep lines from rubbing (beats zip ties!), and/or use a bracket to affix long lines in place to prevent vibration. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
#73052 02/12/2007 7:04 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Fla54; When the engine started up, my oil pressure went to 60 psi for a little while then settled out between 30 and 40 psi. Of course, new oil, filter and a tight engine. Will see how it does after I get a few hundred miles on it.
Freq; Thanks for the tips. May just give them a try. Wasn't very happy with the tiewraps and hose but Hey, it works for now. Really wanted to use billet clamps but couldn't get them to fit the way I wanted. | | |
