| | | Forums66 Topics128,187 Posts1,057,212 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 83 | I need to replace the brake and clutch pedal brass bushings on my '41 3/4 ton and I have a question about disassembling the unit. At the end of the shaft that runs through the pedals, there is a round collar with what appears to be a pin driven through it. I've tried to drive the pin out but it won't budge. Am I on the right track or is there another trick to taking this thing apart?
| | | | | Joined: Nov 2010 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 83 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | not familiar with your truck but if there is a pin in and it needs to come out.....well, it has to come out. Have you tried the online manuals for any help. They may give you some help. http://chevy.oldcarmanualproject.com/Look in the online manuals for your year. Good luck and don't give up. Someone that knows should be by here just anytinme. If not, post a pic and maybe it'll jog mine, or someone elses, memory. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | you need to remove the dowel pin first. then you need to drive out the shaft that the pedal rotates on. the you need to drive out the old brass bushing and reverse sequence when reinstalling everything. my truck was always garage kept plus with all the oil and grease that the parts are caked luckily with mine the pin and shaft came out fairly easy. what ever you do dont break any of the castings in the removal process. the clutch pedal should have a push/pull pin and thats an easy one at least thats how it is on my 40. | | |
