1 members (CuzzFuzz),
101
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 47 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 47 | hi guys, my heater puts out heat even though it's not turned on. that's not so bad now that it's cool outside but it won't be any fun during the summer. it's not that the blower is running but that the heater hoses and the carcass of the heater are hot and the heat flows into the cab. could i correct that problem by putting a manual valve on one of the hoses inside the engine compartment. during the summer i could close the valve and wouldn't that prevent the hot water from entering the heater box and heat from entering the cab. does anyone foresee a problem doing this? thank you. PS, i'm working on a 1950 1/2 ton. heater appears to be original; not sure what kind it is.
Che 1950 Chevy 3100
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There should be a valve to stop the flow. There are several types available. Put it in the hose from the thermostat housing. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Agreed, put it there and it takes the pressure off of the heater core.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | there's one available at NAPA [actually Ford I think  ] that I put in a buddies truck, cable controlled so you can operate it from inside Bill | | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | I agree as well, I put one in my '51 GMC for that very reason.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | 61 to 72 Ford trucks and alot of 60s and 70s Mopars used a valve like that. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I noticed that everyone thinks the valve is a good idea and I agree. But, your problem may be something many guys miss. There is a feed side of the heater and a return side. If you reverse the hoses from the water pump and return, then hot water will migrate up the hose into the heater and heat the whole thing up. These valves can bypass a little water even when turned off The aftermarket in-line valve and the OEM valve need to be hooked to the right hose. Take a look and see if you don't have these reversed.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the correct hookup is the hose from the water pump to the side of the core that has the valve [if original], or if you're putting the aftermarket under-the-hood style valve in, add to that input side, stopping the push of hot water into the core
Bill | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I have this type on my pickup. water valve I'm surprised this thread hasn't been moved. Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2010 Posts: 47 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 47 | i found a near identical one at napa today for only $14, a lot cheaper than the one listed at carters--in case anyone else is in the market for one. thanks for all the advice.
Che 1950 Chevy 3100
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | That's great,hope you get problem under control.
Good luck,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
