4 members (rfs56trk, Chip O, ole green, Hotrod Lincoln), 97 guests, and 10 robots.
Topics128,077
Posts1,056,013
Members48,433
#7292 01/12/2005 2:50 AM
Apprentice
Apprentice
ive got a 261 in my 51 6400. Im trying to decide on which carb to run. ive got a worn out b rochester thats basically trash. tom langdon didnt recommend the h/w for the 261. Im only wanting to run 1 carb. any suggestions. thanks
#7293 01/12/2005 5:19 PM
Anonymous
Unregistered
Anonymous
Unregistered
Carbking speaks highly of the Carter YF carbs on these forums. I've got a 261 also with a Rochester B on it. Next summer I will be looking for a Carter YF from an American Motors 258 inline six to try on my truck. Engine displacement is about the same so it should work pretty well I would think. I've also got a 292 that I will look for a Carter from a Ford 300 inline six for.
#7294 01/12/2005 11:08 PM
Riding in the Passing Lane
The large bore monojets from 68 up work good if you rebuild it right. smile
1972 Chevy c10 Cheyenne Super
#7295 01/14/2005 2:28 AM
I'm running a Rochester "B" from a 250 on my 261 that I swapped the jets and power valve on, and it works OK, but I would find a Carter YF for it since they are more reliable and easier to tune. My "B" has given me a fair amount of trouble and I am good with carbs.
Paint & Body Shop moderator
#7296 01/14/2005 6:34 AM
I used a Zenith carb (228 series) from a GMC 270 on my 261. It bolted right up with no modifications needed to my linkage or fuel line. But,I did have to run a new vacuum advance line, but that was not a big problem.
The best part is that you can keep your oil-bath air cleaner for that "original" look!
