7 members (Deegs53, 78buckshot, Gray_Ghost, Wheelie, Otto Skorzeny, Gdads51, TUTS 59),
198
Mod | | | Forums66 Topics128,078 Posts1,056,022 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 29 Apprentice | | Apprentice Joined: Nov 2004 Posts: 29 | ive got a 261 in my 51 6400. Im trying to decide on which carb to run. ive got a worn out b rochester thats basically trash. tom langdon didnt recommend the h/w for the 261. Im only wanting to run 1 carb. any suggestions. thanks | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Carbking speaks highly of the Carter YF carbs on these forums. I've got a 261 also with a Rochester B on it. Next summer I will be looking for a Carter YF from an American Motors 258 inline six to try on my truck. Engine displacement is about the same so it should work pretty well I would think. I've also got a 292 that I will look for a Carter from a Ford 300 inline six for. | | |
#7294 01/12/2005 11:08 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The large bore monojets from 68 up work good if you rebuild it right.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I'm running a Rochester "B" from a 250 on my 261 that I swapped the jets and power valve on, and it works OK, but I would find a Carter YF for it since they are more reliable and easier to tune. My "B" has given me a fair amount of trouble and I am good with carbs.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2003 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2003 Posts: 94 | I used a Zenith carb (228 series) from a GMC 270 on my 261. It bolted right up with no modifications needed to my linkage or fuel line. But,I did have to run a new vacuum advance line, but that was not a big problem.
The best part is that you can keep your oil-bath air cleaner for that "original" look! | | |
