7 members (Bill Hanlon, Tom McGrath, Rich'sToys, Jman, Robert Crandall, Steelonsteel, Wally / Montana),
85
Mod | | | Forums66 Topics128,035 Posts1,055,556 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | I'm almost finished repainting the inside of my cab and now my gauges are looking a little shabby. I want to re-face them. Does anyone have anything to say about these decal kits? Are they the same from all vendors or is there one thats better? Any info or tips will be greatly appreciated. Thanks! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I have a set that has been on my 37 for 10 years now and still look nice. I also used them on my 52Panel guages and they look good to.
Advice? Make sure the face is CLEAN CLEAN CLEAN. A small pice of "dust/grit" will show as a tiny "bubble". I ended up with a couple of these on one of the panel guages but after putting the faces ect on you can only barely see them if you look hard!!
I like them. I suspect most are from the same place???... | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | I bought the decals and removed the gauges, I wasn't really happy with the match of colors and the alignment .
I sent out the gauges to be done,and it was well worth it
Where in CT, I still have some of the decals | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | Where did you send your gauges? How long did it take and how much did it cost? (I'm on a tight budget). I'm in northern Middlesex county (about 20 min. south of Hartford. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | For what its worth dept. D&M Restorations in Greenville, S.C. can actually screen print them like original and they do really good work. Been in business for years, but....it all comes at a price so let your conscience, well, let your pocketbook be your guide!! | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | OK I got my instrument panel out. I've read the Tech Tip about restoring the speedo and I have some concerns about the other gauges. I understand you have to sand the gauge faces to prepare them for the decals. With the speedo you can remove the needle and the face to work on it the others you can't (at least not easily). Is there a trick to it? or do you have to be really really careful? Does anyone who has done this have any advise for a first timer? Any help would be greatly appreciated. Thanks | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ct artdeco...I can only speak for myself. I recently did my guage faces myself. Mine were not in "terrible" shape so I used some fine sandpaper and it did well. you do not have to take them to "bare" metal...just have to be smooth. I worked SLOW on them. This is one time we can't rush things. Be patient.
I might add that just before sticking them on be sure there is not grit/dust on the guage. It will show as a little speck under the decal...I had this happen to me on one of the guages but by the time I put the faces/glass ect back on and in the dash you can't see it unless you "stare at it". Go for it. You can do it!
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | As far as sanding the gauge units, like its been mentioned before, just go slow and easy. I used 220 grit on a foam block, then followed up with 320 on the same block. Going to put decals on tonight. | | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | I bought my decals from Jim Carter, I cleaned the gauges real good them wiped with alcohol. I took my time, And was very careful in doing it. They turned out Great, They look like new!
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I also redid mine a while ago. First timer. I laid everthing out, made drawings and took pictures. Did I say I read alot here on the forums. All went well. Pictures may help. Some start here. May or may not help. Have fun and good luck Dan | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | found that some aeresol window cleaner, such as sprayway works great to pull up grit, grime, dust and anything else you don't want on your gauges before you apply. | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | I got mine done last month with a few minor difficulties. First I read all the Tech Tips (many times) and looked up past threads on the forum. I had trouble getting the speedo needle off. The two screwdrivers would NOT work, finally I grabbed the needle shaft under the faceplate with mini needle nose pliers and used a dinner fork to pop the needle off (worked really well, but it needed quite a bit of force). I cleaned the gauge faces with 200 grit sand paper and cleaned them with alcohol. Then put the decals on as the directions showed. The next tricky part was cutting the hole for the high beam indicator. I used a pin to make a hole through the back and the used a exacto knife to cut the hole from the front. They came out great! The interior is going together and the truck will be back on the road for the summer. Thanks to everyone on Stovebolt for all the help. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I use a slight counter clockwise force as I pull to remove the needle. That keeps the mechanism against the stops. I have used this on several units with success. | | |
