Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (jmoore, frogfarmer, Jon G), 105 guests, and 4 robots.
Topics128,288
Posts1,058,574
Members48,492
#729281 03/12/2011 10:16 PM
I am putting a t-5 trans in my 54 3100...I have heard that I can replace my existing (torque tube) rear pumpkin with a pumpkin from a 55-56-57 1/2 ton(3100). It is supposed to be an easy swap...Anybody with advise?????
A '55 to '62 1/2 ton pumpkin will work. You have to weld up your spring pivots on the housing when doing the swap.
Steve
'49 3800
'52 3600
'57 3100
Steve is right on them money. I used a 56 in mine. Swap is easy. Check Axle seals while you have the axles pulled out.
yep,I used a 1958 in mine,3:90 gear ratio.
1951 3100 Chevrolet
