4 members (Woogeroo, klhansen, jay d, 1 invisible),
130
Mod | | | Forums66 Topics128,288 Posts1,058,577 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 8 New Guy | | New Guy Joined: Nov 2009 Posts: 8 | I am putting a t-5 trans in my 54 3100...I have heard that I can replace my existing (torque tube) rear pumpkin with a pumpkin from a 55-56-57 1/2 ton(3100). It is supposed to be an easy swap...Anybody with advise????? | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | A '55 to '62 1/2 ton pumpkin will work. You have to weld up your spring pivots on the housing when doing the swap. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Steve is right on them money. I used a 56 in mine. Swap is easy. Check Axle seals while you have the axles pulled out. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | yep,I used a 1958 in mine,3:90 gear ratio. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
