| | | Forums66 Topics128,108 Posts1,056,227 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10 New Guy | | New Guy Joined: Mar 2010 Posts: 10 | HI, can any one tell me where to find replacement ft. shocks for my 1 ton ? I can find shocks listed for 1/2 & 3/4 ton all day long.Will a 3/4 ton shock fit 1 ton ? Thanks for any help. | | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | You don't say what year, but the correct shocks for the front are available. I think I got mine at Jim Carters. As far as I know, there is nothing special about them and you could probably buy them at your local flaps. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Check your local parts house. They have Monroe here for under $40.
Bruce | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | NAPA has them. I put the tube style shock in my '48 3800, 18 yrs ago. They are Monroe. And I got them for a '53 3800, and changed the mounts on my '48 frame. | | | | | Joined: Mar 2010 Posts: 10 New Guy | | New Guy Joined: Mar 2010 Posts: 10 | My 3800 is a 1954 ,the local napa and advance auto say they do not have a listing but could cross ref if I had #.I've could not find a listing in LMC truck,Chevs of the 40's,Classic Chevy,Obsolete Chevy Parts,inc,Kanter,ect. If any one has a part # that may be very helpful. thank you. | | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | Jimmy Caters item number is ME833. I bought mine there, they are a name brand, cut I forget what it is. | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | NAPA has them. I put the tube style shock in my '48 3800, 18 yrs ago. They are Monroe. And I got them for a '53 3800, and changed the mounts on my '48 frame. wbrowne - I have the knee action shocks on my truck - did you have the same before you changed to tube style? | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Bigtonka- Yes, orginally my truck had the lever action front shocks. I changed the lower shock mount plate that is held in place by the front axle U-Bolts and then I mounted the upper shock mount brackets from a '53 onto my frame. Then installed the tube shocks. It was more cost effective going this route instead of having the original lever action shocks rebuilt to the tune of $150. each!
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | I'd love to see pics of that. | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Hi Bigtonka -Sorry no photos available at this time. The photo dept. personnel is away on vacation. I'm not permitted to handle the cameras, 'cause I screw them all up. I'm in charge of the "wrenching", welding, metal fabrication depts. Will try to get some photos to you soon. | | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | Hey buddy! see how much the postage is from US 72126 & I'll send you the shock mounts off my 51 3800 parts truck. US postal service has flat rate shipping boxes, that may be cheapest. I got great quality gas shocks from classic performance products. they're listed for 1/2 tons but are bigger around & have a larger piston rod than the oem shocks that were on it. DDefinite improvement while you're at it you may as well order a swaybar from them too. | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Robert - that's awesome! I'll try to get that shipping cost worked out ASAP!
Tks! | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Bigtonka - I sent you a PM re: photos. | | | | | Joined: Mar 2011 Posts: 3 New Guy | | New Guy Joined: Mar 2011 Posts: 3 | | | | | | Joined: Jan 2011 Posts: 35 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 35 | If you didn't find a replacement (my local Napa couldn't find any), I got a pair of KYB GR-2 #343219 gas shocks from Dan's Classic auto parts in Portland. They were ~$28/each. | | |
