9 members (Nhluvstruck, 32Fordpuchoptop, Bill Hanlon, DHedrick, Ponchogl, Southerntruck, Otto Skorzeny, 1955 1 Series, 1 invisible), 125 guests, and 0 robots.
Topics128,114
Posts1,056,283
Members48,439
#725979 03/02/2011 9:18 PM
HI, can any one tell me where to find replacement ft. shocks for my 1 ton ? I can find shocks listed for 1/2 & 3/4 ton all day long.Will a 3/4 ton shock fit 1 ton ? Thanks for any help.
tonyt #726018 03/03/2011 12:04 AM
You don't say what year, but the correct shocks for the front are available. I think I got mine at Jim Carters. As far as I know, there is nothing special about them and you could probably buy them at your local flaps.
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
Check your local parts house. They have Monroe here for under $40.
Bruce
My Trucks
Stuff I Collect
NAPA has them. I put the tube style shock in my '48 3800, 18 yrs ago. They are Monroe. And I got them for a '53 3800, and changed the mounts on my '48 frame.
My 3800 is a 1954 ,the local napa and advance auto say they do not have a listing but could cross ref if I had #.I've could not find a listing in LMC truck,Chevs of the 40's,Classic Chevy,Obsolete Chevy Parts,inc,Kanter,ect. If any one has a part # that may be very helpful. thank you.
Jimmy Caters item number is ME833. I bought mine there, they are a name brand, cut I forget what it is.
RIP good friend.
wbrowne - I have the knee action shocks on my truck - did you have the same before you changed to tube style?
Bigtonka- Yes, orginally my truck had the lever action front shocks. I changed the lower shock mount plate that is held in place by the front axle U-Bolts and then I mounted the upper shock mount brackets from a '53 onto my frame. Then installed the tube shocks. It was more cost effective going this route instead of having the original lever action shocks rebuilt to the tune of $150. each!
I'd love to see pics of that.
Hi Bigtonka -Sorry no photos available at this time. The photo dept. personnel is away on vacation. I'm not permitted to handle the cameras, 'cause I screw them all up. I'm in charge of the "wrenching", welding, metal fabrication depts. Will try to get some photos to you soon.
Hey buddy! see how much the postage is from US 72126 & I'll send you the shock mounts off my 51 3800 parts truck. US postal service has flat rate shipping boxes, that may be cheapest. I got great quality gas shocks from classic performance products. they're listed for 1/2 tons but are bigger around & have a larger piston rod than the oem shocks that were on it. DDefinite improvement while you're at it you may as well order a swaybar from them too.
Robert French MY3800FIRETRUCK
Robert - that's awesome! I'll try to get that shipping cost worked out ASAP!
Tks!
Bigtonka - I sent you a PM re: photos.
saw some on ebay today
If you didn't find a replacement (my local Napa couldn't find any), I got a pair of KYB GR-2 #343219 gas shocks from Dan's Classic auto parts in Portland. They were ~$28/each.
Moderated by  Dusty53
