| | | Forums66 Topics128,034 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 90 | I have a 1937 1/2 ton that needs a re-wire job. I want to convert to 12volt and add turn signals, another tail light and possible upgrade to LED lighting. In the cab all I would add is possible a small stereo set up and I want to put the fuse block under the seat, (fuel tank is no longer under the seat)
Looking for suggestions on a good wiring harness with the proper amount of circuits and equipment I need.
Thanks, Charlie | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Go to the Links here and you'll find several....and different prices! With what your suggesting 12 circuits would work but you can find harnesses with more circuits for about the same money. Personally, for value to dollar, I like Rebel and EZwire. Rebel wire was giving Bolters a 15% discount off their already good prices..... however, I went with EZWire as I wanted the "mini" fuse set up. Lots of options out there so put on your reading glasses and get started  Say, how about a picture of your 37 when you can get to it. | | | | | Joined: Sep 2010 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 90 |
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Wow....she looks in great shape ! I picked up a Painless 18 Cct. universal truck kit on E Bay for a good price. Didn't need 18 Cct. but nice to have a few spares for future ( P windows, Air, Elec. fuel pump, etc. ) | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Wow, that is a nice looking truck! Did you buy it like that? | | | | | Joined: Sep 2010 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 90 | I did buy the truck in its current condition. I am very luck with this truck because it was bought new by my great grandfather and has been in the family its whole life. My uncle owned the truck from the late 80's to last Sept when I bought it from him and he did a fairly detailed restoration on it in 89. | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I made my own wiring harness for my 37 with inline fuses since there are not many curcuits,it was very easy to do since I just sat the cab back on the chassis and made the wires longer then needed and cut them and added ends when it came togather. I drew up a schematic and the colors of the wires I wanted and bought bulk wire and quick disconnects so it could be servicable. | | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | Great looking '37!  | | |
