7 members (3B, Phak1, 1955 1 Series, Gib70, Joe H, KEVINSKI, 1 invisible),
133
Mod | | | Forums66 Topics128,092 Posts1,056,451 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 35 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 35 | Hello all.
Just getting around to replacing the linoleum floor (with rubber flooring, for now) and was wondering if there is a pattern (and detailed specs) for the floor, including where seat posts go and ideally the contours of the flooring. Or, what have others done to get their new flooring measured and cut correctly? If there is a thread already, point me to it. Couldn't find anything specific.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have never seen a factory pattern (or specs) for a 47-55 Suburban rear floor.
Do you still have the original rear floor plywood in your suburban?
Do you have the floor plates that go under each seat-floor bolt?
If you have the above items, have you tried to make a pattern?
I made a pattern by placing roofing paper over the floor, placing the floor plates in place, and drawing where the cut-outs and edges would be.
If you do not have any linoleum left, you would not know how the width of the lengthwise grooves. Are those the "contours" you refer to? I'll measure that, if you want (I dimly recall that they were about 3/4" apart but that is a guess).
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | There was a guy who claimed he was in the process of having them reproduced.We haven't heard from him for a long time. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Contact WEEDS , I am sure he used a pattern when he redid his floor in the suburban. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | might work some info out of this thread and the links therein Bill | | | | | Joined: Aug 2009 Posts: 35 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 35 | Thanks all. I have chatted with Weeds and look over several posts. I think I just have to do the best I can in making a pattern. Was hoping for something out there already put together. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Torman, come over to the ranch, I have a burb floor sitting outside you can use for a pattern. .................g | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you still have the original rear floor plywood in your suburban?
If you have the original floor and plates, it would take about an hour of work to make a template/pattern (plus buying the roofing paper).
| | | | | Joined: Aug 2009 Posts: 35 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 35 | | | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | yes, there was a guy who said he was going to make this flooring. and was to send me samples that I just never got. he had my address etc. and I sent many photos
but, nothing Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
| | | | | Joined: Aug 2009 Posts: 35 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 35 | Yeah, I am going with a rubber flooring for now that looks great. Some SB in the Midwest suggested it (available at farm supply stores) and I think it will work great (until there's a more original option). | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I have been keeping my eyes open for rubber flooring wide enough to go wall to wall but have not found anything yet. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | It's out there. You can get it in 5 or 6 foot widths. Google American Flooring for example. It won't be cheap, but it's out there. Did someone say that Tractor Supply has some wide width rubber? Maybe. | | | | | Joined: Aug 2009 Posts: 35 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 35 | | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | I saw somewhere it showed someone step on redoing the wood floor itself does anyone have the link? and is the wood held in form the under side by those square nuts? top side are domed like carrage bolts? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I saw somewhere it showed someone step on redoing the wood floor itself does anyone have the link? and is the wood held in form the under side by those square nuts? top side are domed like carrage bolts? WEEDS Lot's of pictures too! | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | I saw somewhere it showed someone step on redoing the wood floor itself does anyone have the link? and is the wood held in form the under side by those square nuts? top side are domed like carrage bolts? WEEDS Lot's of pictures too! Thanks you always come thru | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | You will need a grinder, it's welded in. | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | You will need a grinder, it's welded in. On the flat side or up and down side or both? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | You will need a grinder, it's welded in. On the flat side or up and down side or both? It should be visible from the top side against the body panels/wheel wells. No welding from below. BTW: I have not done this, so I am guessing the grinder would be the best tool, you may need to use a chisel to minimize any damage. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Spot-weld cutter would be useful. There are over 20 spot welds that hold the angle strip to the side wall. Have you removed the paint from the strip? After doing that, you should be able to see the spot welds.
Do you intend to remove the plywood floor in one piece (and replace it as one new piece)?
I have not removed that strip or the floor, but I talked with a person who had done it. I cannot remember if, after the metal side strip was removed, the wood could be angled out the rear door, or if the wood had to be removed from below (with the body off the frame).
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Spot-weld cutter would be useful. There are over 20 spot welds that hold the angle strip to the side wall. Have you removed the paint from the strip? After doing that, you should be able to see the spot welds.
I have not removed that strip or the floor, but I talked with a person who had done it. I cannot remember if, after the metal side strip was removed, the wood could be angled out the rear door, or if the wood had to be removed from below (with the body off the frame). No i have not removed the paint yet i guess i better LOL i didnt even think about it being spot welded in and yes i plan on to atleast try and get the wood out in one peace and new back in | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | When I had my rear body panel off of my 'Burb it seemed you could tilt the wood down and slide it out. With the wood tilted down you would clear the inner wheelhouse panels. The rear body panel came out pretty easily, and there were only a couple -4- welds or so to remove. Just a thought.....
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I agree, Phillip. With the rear rear body-panel/skirt off the floor board should come out OK. If someone tried that, do you think they would have to worry about the body spreading outward a little?
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | When I had my rear body panel off of my 'Burb it seemed you could tilt the wood down and slide it out. With the wood tilted down you would clear the inner wheelhouse panels. The rear body panel came out pretty easily, and there were only a couple -4- welds or so to remove. Just a thought..... Did you still take the other trim off too or did u just take the back one off ? | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Tim, when I pulled my rear body panel off the sides of the body were very stout. I never moved the body around when it is was without the rear body panel but it seemed sturdy to me.
BigTony, I only removed the rear body panel so my body tech and I could properly repair the inner lower quarter panels. I never actually pulled the floor. But at that time I realized with a little effort it would come all the way out with just a little more effort.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Ok i took one upper side off at the spot welds and we where able to get the floor out it was a work out for sure the problem was where the wood is wider at the front so it was a SUPER tight squeeze LOL http://i89.photobucket.com/albums/k237/bigtony55/IMAG1618.jpg | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Nice! Nothing worth while is ever easy.....
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Bigtony55, you have accomplished what we have been saying was impossible for quite awhile! We have had great discussions on this subject and it was determined that you could NOT remove the wood from the top. Could you go into a little more detail on what it took you to remove it? Thanks | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I was thinking the same thing as you George.I hope you took some step by step pictures of the process.
Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | bigtony55,
Yes, pictures please. This post should go into a hall of fame. A few people have posted that removing the floor out the rear opening was not possible but I doubt if they tried.
How many spot welds were there? I think I was told 28 but I did not try to count them when I had my metal stripped down.
Thanks for the update/clarification.
If you will be making a new, single-piece replacement floor, be sure to take photos and let us know how this went.
Oh yeah, how many spot welds did you have to cut?
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | bigtony55,
Oh yeah, how many spot welds did you have to cut? If i counted right it,the holes in side of panel anyways its 16-17 i wasnt 100% if the 17s was a hole from spot weld or not i had my buddy in there doing it for me | | |
