1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | I want to install an underbed gastank for my 54 chevy 3100. Soon I want to mount it to a 1964 Chevy Frame. What would be a good tank to use? Is there one I can get from a donor vehicle that will fit nicely? or would I have to get a new one? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | You may want to ask this in the 60-66 Forum. Most of us are creature of habit and go to the same places and seldom look elsewhere. So the guys who may have done this would have a better shot at seeing your post. | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | The back part of the frame either a 54 or 64 should be the same since the beds are the same. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | The only caution i have is be sure that the tank is located in such a way that it can be removed without removing the bed. mine was installed with mounting flanges on the top of the rails. now that i want to install new bed wood the tank has to be dropped. or if you have to change the sender same thing.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | what gas tank did you use?
| | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | I am right now in the process of installing a tank from 83/87 subaru not sure witch model i picked it up about 5 years ago and now the tank shop is closed so i am unable to find out for sure.It fit's nicely up in the spare tire pocket and has the one wire sending unit. Only thing i don't like is that it will show from the rear below the bumper. I guess i will go with it for now and keep an eye out for something better.
layback
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I've got a frame mounted tank from a 47-48 if you're interested.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Beast 54 I used a tank from a 83 el camino between the back rails of my 49 suburban. I had to slightly massage the seams which stick out an inch or so but no leaks so all is well. It has fuel pickup in the top and a side mounted neck which I will run out to the fender. So think about chevelles, etc in that year bracket. Problem is first things most yard do is punching holes in tanks for insurance purposes.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | check your PM mobileortho | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | The company i got my tank from is out of business now.
| | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Mobileortho, Do u still have your '47/'48 tank and if,do you want to sell it? Thanx, Mike | | |
