Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (MickeyP, baldeagle, Gdads51, Hotrod Lincoln, klhansen, KingG), 56 guests, and 0 robots.
Topics128,007
Posts1,055,281
Members48,418
#72713 02/03/2007 2:45 AM
I am getting ready to mock up my motor & tranny. Should I put the motor mounts over the front cross member or should I get the motor as close to the fire wall as possible then weld the mounts were they line up with the motor. I have a small block & a 700r4 tranny. should the tranny be lower then the floor board. I just have the block for mock up purposes, do I need any thing else on the motor to set the angle. thanks for the help
If it was easy, everybody would be doing it.
#72714 02/03/2007 4:36 AM
what year truck?? I'd try to have the whole drive line to set the angle, the pinion angle's necessary, which relates to the trans
#72715 02/03/2007 7:02 AM
I have a 41 chevy 3/4 ton special
