9 members (Tronman, tclederman, Bill Hanlon, Otto Skorzeny, Hotrod Lincoln, carbking, 49choptop, Guitplayer, John L.), 145 guests, and 4 robots.
Topics128,042
Posts1,055,501
Members48,424
#72713 02/03/2007 2:45 AM
I am getting ready to mock up my motor & tranny. Should I put the motor mounts over the front cross member or should I get the motor as close to the fire wall as possible then weld the mounts were they line up with the motor. I have a small block & a 700r4 tranny. should the tranny be lower then the floor board. I just have the block for mock up purposes, do I need any thing else on the motor to set the angle. thanks for the help
If it was easy, everybody would be doing it.
#72714 02/03/2007 4:36 AM
what year truck?? I'd try to have the whole drive line to set the angle, the pinion angle's necessary, which relates to the trans
#72715 02/03/2007 7:02 AM
I have a 41 chevy 3/4 ton special
