| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | Ok, I just got a 60 apache and the roof is rotted (the worst I have ever seen) so I'm looking at cab replacement which is sad cause the floorboards and rockers are in perfect shape, anyway, when I switch cabs how do I go about putting the origonal nominclature plate back on the pillar legally (or do I just do it  ) | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i always figured it is just replacement sheetmetal, like a fender - so my vote is "just do it". one man's opinion only. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Up until less than a year ago, I was a licensed salvage dealer. It is common to put a replacement cab on a damaged vehicle. I am also in the trucking business and several of my trucks have had replacement cabs installed. I would just do it. If you ask some enforcement agency, they may want to show off their authority and tell you all sorts of BS. As a salvage dealer I was audited periodically. I just made sure I could document the origin of the cabs I installed. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Use the title that comes with the cab you use. | | | | | Joined: Nov 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 78 | The bottom is perfect but the top is shot? Was it sitting on its roof? 1959 Chevy 3/4-ton (pics posted soon)
I child-proofed my house, but my kids keep finding their way back in. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I have simply done it & told no one-around here DMV & law enforcement couldn't care less if the vehicle is over 10 y/o. | | |
