| | | Forums66 Topics128,078 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 19 New Guy | | New Guy Joined: Aug 2010 Posts: 19 | I'm considering removing my rear doors in order to replace some door skin. Currently the doors fit perfectly and I am worried about how difficult it will be getting them realigned as well? Just popping the hinge pin would be simple enough, right? But I am considering removing the hinge entirely in order to replace the rubber grommet against the body. If I paint the outline of the hinge, will this be enough to get it reinstalled correctly or will I have to battle with the alignment? Maybe I should do the repair with the doors on? | | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | The rear doors are difficult to align since there is virtually no adjustment allowed for in the hinges. But I found on mine that once the doors are properly aligned, that it has been a fairly simple procedure to remove and replace the doors. So I think you may be ok, as long as you don't change the shape of the doors when you re-skin them; but then that would be an issue even if you re-skin them while mounted. Good luck. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Dang, I can't remember how mine looks and its only been a few months since doing them...BUT, I've heard tell of folks drilling a hole, where they can, and put a roll pin in the hinge so they get it back exactly where it goes.... maybe you can do something like this on yours?.... dang it, now I have to go look at mine and see if what I said can be done!! | | |
