2 members (Rnl364, baldeagle),
56
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 10 New Guy | | New Guy Joined: Nov 2010 Posts: 10 | How do you know if your engine is a 230,235,250,292 when you have a straight six. I have all the numbers off the block and head but can't seem to find any sites where they can tell me what size engine I have. I have bought replacement parts for my motor and have been gambling with 230 size and seem to be doing pretty good so far. Any one have any suggestions?
1965 Chevy Straight Six Lover
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Try Inliners International for the casting numbers, which will get you close (there's some overlap on 230 and 250 blocks). The 235 and 292 will stand out as different. The 235 is a different engine design, no parts interhchange with the 230/250/292. That one was discontinued in the US in '62 (some '63 4x4s may have used them, though). The 292 has a few differences from the 230/250, mainly the feul pump is in a different location, and the block has a taller deck hight. Otherwise, they are very similar. If you have the stamped serial number from the pad next to the distributor, you can post it here to get it decoded.
Bill Burmeister | | | | | Joined: Nov 2010 Posts: 10 New Guy | | New Guy Joined: Nov 2010 Posts: 10 |
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's either a '65 230 or a '66 250. According to the code, it was built on June 2nd, you'll need to find a casting date to get the exact year.
Bill Burmeister | | | | | Joined: Nov 2010 Posts: 10 New Guy | | New Guy Joined: Nov 2010 Posts: 10 | The codes I found where a E285.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Ok, now we've got it! E285 is May 28th of '65, which matches up with a June 2nd asembly date. Your engine is a 230.
