| | | Forums66 Topics128,049 Posts1,055,653 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#72437 01/30/2007 2:53 AM | Joined: Oct 2006 Posts: 13 New Guy | | New Guy Joined: Oct 2006 Posts: 13 | fill up 56 and drove it . the next morning i would not start. try stared fluid, cranking but no start.then a noticed liquid or maybe fuel dripping from side of the carb. i not the mechical type but i miss driven her but do not know what's wrong HELP PLEASE IS THIS A PROBLEM ON THE STOVEBOLT IT IS THE ORGINAL MOTOR. does anyone know a good shop in san jose,ca | | |
#72438 01/30/2007 4:12 AM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Sounds like you are flooding it. Several things could be the problem. Have you lost spark? Pull a plug and see if it is wet with fuel. Try a dry plug hooked up with the base grounded. Have a buddy turn the motor over. Do you see spark. If not, your startig point is electrical. If you got fire then the carb is next thing, maybe a stuck float.
#72439 01/30/2007 4:12 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | skip the starter fluid .... and check for spark - if you haven't been driving it much the points may be 'oxidized' - the dripping carb will be that you flooded it cranking and pumping the pedal
Bill | | |
#72440 01/30/2007 5:02 AM | Joined: Oct 2006 Posts: 13 New Guy | | New Guy Joined: Oct 2006 Posts: 13 | thanks you for the fast response it going to try it and will post the outcome | | |
#72441 01/30/2007 7:29 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | If your motor is flooded, the quickest way to "unflood" it is to hold the gas peddal to the floor and crank the engine over. Don't pump it any more and make sure the choke is open. The engine will start to fire when the gas is mostly cleared. | | |
