4 members (TUTS 59, Forty9, mo2cyl, Stovebolt48), 39 guests, and 2 robots.
Topics128,031
Posts1,055,436
Members48,422
So im curious if anyone knows where i might be able to locate a proper window seal for the rear clamshell liftgate window? my glass guy said the universal locking strip type wont work because the window is actually bigger then the frame so the slots for the pinch weld and glass need to be next to each other if you were looking at a cross section. I cant find anything that looks like itll work anywhere.......
year might help find an answer, but I'll suggest checking with Steele Rubber
Marc what you're looking for is what's called an 'S' section rubber,as opposed to the 'H' section commonly used.
I'm sure there's a supplier in the U.S. but over here I use a company called C.O.H. Baines they have an online catalogue showing all their profiles in 1:1 scale.
Might be worth a look even to see if they have anything close.
Ideally you'll need someting with 1/4" glass groove and 1/8" pinch weld groove.
I hope this in some way helps.
Good luck.
More pix on Flickr.
I got mine from Steele
Steele Rubber: Suburban upper lift-gate, 60-0609-81
thanks guys for the info. i literally was just browsing thru my jim carter truck catalog and found it. tho the pic shows the H style lock strip so thats why i must have missed it. Ill go look for it in steele too. thanks again guys!
Marc - sounds like you may have the wrong glass for the opening, was it in the truck originally or is it a replacement piece you got?
I used one from Jim Carter. I put it in myself. It took all of 15 minutes. Piece of cake and fitted well. Steele's products are typically really good. I used them on my windows for the 51 chev.
No I have the right one, I literally just had been over looking the part in jim carters for a week! Guess since they dont show a true picture of what it looks like that i never stopped to read the description! Ill be ordering it from the asap. this truck is my first ground up restoration and first ever time dealing with a truck of this era. Is it me or do these trucks take a lot of quarky little parts?? three seals per door.....really?? Advanced design??? i guess for 60 years ago..... everytime i turn around i need something else. i dont think i could of predicted all that this projected needed ever! hahahaha
Marc,the rear glass certainly sounds like it installs in the same manner as the front windshields.
That is the glass is slightly larger than the aperature.
Hence the 'S' section seal.
As Patrick (pplumber) says it should be a fairly straight forward install.
Is the window tempered or laminated?
It's easy to tell by looking at the edges.
You'll have to excuse my ignorance but Clamshell 'burbs are like hen's teeth,even more so here and I have no references to work with.
Let us know how you get on with it.
More pix on Flickr.
Nice info thanks
Stovebolt CHEVROLET
1949 Chevrolet Suburban
Non stovebolt CHEVROLET
1958 Impala Convertible
1963 Impala Convertible
MY 1949 SUBURBAN
big tony I used the Steele product. It seems to cost more than at some of other vendors but I know where it was made smile Had no issues. Just go slow and use plastic or wood "sticks" to help seat the seals in the corners. Good Luck
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
Having two people really helps the installation. Also, soak the rubber in an excessively hot and soapy solution. If the door is attached to the body, be sure to lay down a thick bed of foam if you drop the glass (the soapy water makes it slippery). I took mine out and did it on the floor.
