| | | Forums66 Topics128,157 Posts1,056,885 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | It is funny how the passenger side of my 48 goes together and looks fine but the drivers side is all out of wack.
The front fender does not fit, the door needs to be pushed out at the top hinge, the middle step bracket is pushed up, and the fender is back a little in the front - so the step does not attach.
Funny
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Boy, what a pain...hopefully it won't take too much tweaking to line things back up.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks. I was venting. When buying upgrades, or better looking parts, they don't fit the same as the 'original' crumpled parts.
What it looks like is I will have to bend the front flange on the cab where it meets the fender, shim out the door where it meets the top hinge, and bend/pull the rear fender forward. I am not sure about bending the hinge. The door fits fine in the back and I am affraid I will put that out of wack. Finally, I am not sure what to do about the middle step bracket? I think the PO must have jacked up the truck by this bracket.
Any suggestions?
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I've straightened out running board brkts by slipping a long pipe over the brkt and bending it around. Measure the mounting points on your board and compare to the brkts. It appears that your truck had been abused on the left side? Hopefully you can find a "straight" place to start and work from there. | | | | | Joined: Mar 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 66 | Did the truck ever get hit hard, maybe the frame is bent,I have seen it where a full frame gets hit front/back or side and one of the rails get moved depending on the hit and it will move a whole side out of line or the frame could be bent up or down in your case front and will get the same results, if you have to do that much tweeking it sounds like you may have a bigger problem you may ned to cross measure the frame.Are all the parts oem because I have tried to put some after market parts on and fight for days and it was the parts not the truck. / just a thought | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks Glen but I believe it is the parts. I was curious about the step bracket. It is creased and appears to have been used to jack the truck up.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I fixed the front fender to fit and noticed the step bracket only sticks up a little. So, it should all work.
Thanks for all the help.
