| | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | I've got a Rochester carb on '50 3100. Where does the throttle cable connect to? I know the bracket points it downward, but I can't tell where/how it connects. Any advice would be appreciated...especially a picture!! thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The wire from the cable goes through the hole where a cotter pin would go. There is a stop that goes on the end of the wire. As the foot feed works, the linkage slids up & down on the wire. The stop is obtainable in the Motor Mite Help line of parts. Carquest & other parts stores handle that line. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | fantastic wrenchbender; thanks! | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | About any FLAPS or lawnmower place should have wire stops (sometimes called a cable stop). <CLICK>
| | | | | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | thanks; just so I understand, if the throttle cable is threaded through the foot feed linkage, you don't need a cotter pin because the throttle cable will keep the foot feed linkage connected to the carburetor. Or do you still need a cotter pin to keep the foot feed linkage connected to the carburetor? thanks again. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | No. There was nothing else in the hole. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
