4 members (Charles in CA, Shade Baby, Hotrod Lincoln, 46 Texaco), 119 guests, and 3 robots.
Topics128,162
Posts1,056,913
Members48,458
I've got a Rochester carb on '50 3100. Where does the throttle cable connect to? I know the bracket points it downward, but I can't tell where/how it connects. Any advice would be appreciated...especially a picture!! thanks
Riding in the Passing Lane
The wire from the cable goes through the hole where a cotter pin would go. There is a stop that goes on the end of the wire. As the foot feed works, the linkage slids up & down on the wire. The stop is obtainable in the Motor Mite Help line of parts. Carquest & other parts stores handle that line.
1972 Chevy c10 Cheyenne Super
fantastic wrenchbender; thanks!
Ex Hall Monitor
Ex Hall Monitor
About any FLAPS or lawnmower place should have wire stops (sometimes called a cable stop). <CLICK>
thanks; just so I understand, if the throttle cable is threaded through the foot feed linkage, you don't need a cotter pin because the throttle cable will keep the foot feed linkage connected to the carburetor. Or do you still need a cotter pin to keep the foot feed linkage connected to the carburetor? thanks again.
No. There was nothing else in the hole.
