6 members (Tronman, wilbur53, Jon G, GMCJammer51, Hotrod Lincoln, 1 invisible), 85 guests, and 2 robots.
Topics128,109
Posts1,056,569
Members48,448
#723986 02/24/2011 4:34 PM
Im going to build up a 250 I6 for my 54 chevy truck and I picked up a TBI from a 1993 Chevy Suburban for the 250 I6. Will this work well or am I going to run into some probles? Or does all TBI's work with either 8 or 6 cylenders?
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
It should work just fine. You'll need an adapter. Maybe an aftermarket 4 bbl carb intake manifold will work. You'll probably have to just try it and see, since I think the oxygen sensor you'll have to install on your exhaust should be able to adjust for the fuel needs. Interesting idea.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
you might use a throttle body from a 4.3 V6
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
if I get a TBI from a v6 will I need the computer from that car too? HOT ROD DAD has a good point I think with the O2 sensor adjusting the fuel for it. ????
