2 members (R&S 51 GMC, Tiny),
152
Mod | | | Forums66 Topics128,125 Posts1,056,338 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | is there a diagram or picture of where to tap the block in order to get full flow of oil to the external filter i read about it in this forum but can't find the thread
thanks
1963 c10 | | | | | Joined: Jan 2011 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 85 | I think most put a T on the oil pressure gauge hole in the block.
52 Chevy 1/2 ton - work in progress 65 Mustang coupe - work not in progress  67 Mustang GT convertibile 67 Camaro RS/SS We are now even with fords and chevys. Now i need a mopar. Hahahahahahahahaha
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | What you seek is in the tech tips: http://www.stovebolt.com/techtips/full_pressure.htmPersonally I will never do this modification as I believe fitting a high performance bypass filter will do a better job.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | thanks guys i think i'll see what the mach shop guys think i have an external filter and thought i may as well use it
1963 c10 | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | ok thanks again if i go with the tee off the pressure port where does the return line go in?
1963 c10 | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | rgie,
You did not state the year and size engine (and it is not in your profile). You prior posts refer to a 261 (maybe a 1959) and a 235 (maybe a 1954).
What year and size engine?
| | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | thanks guys i think i'll see what the mach shop guys think i have an external filter and thought i may as well use it Is the external filter a bypass or a full-flow? Only a bypass filter ban be used with the 1/8" tee off of the oil pressure gage fitting. The link that Curt provided is for the full-flow filter, using 3/8" fittings. I installed a full-flow filter using those instructions. However, subsequent research has just about convinced me that a good bypass filter may be better. Hoyt | | | | | Joined: Jan 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 83 | Hoyt, I am with you. I did my 54 with the full flow conversion. I am going to build my 49(with a 1954 235) with a bypass filter and plan on schedualed oil changes. These engines were built to last and the filter was an option at the time! | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | i am speaking mainly about the 54 235 engine i do have a 261 however i don't know what year it is since there is nothing stamped on the pad by the dist i would do that too. the ext oil canister was given to me plus i have another one that is currently on the 216 that i will replace with the 235 (going into a 51 3100)
i am leaning toward the bypass filter. is there a diagram of how that would be set up? thanks
1963 c10 | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | thanks tim i did look it up and the 261 is a march 59 block what i need now (not right now) is an 848 head for it thanks everyone
rolf
1963 c10 | | |
