Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (baldeagle, carbking, 2-Ton), 28 guests, and 3 robots.
Topics128,005
Posts1,055,254
Members48,418
#723877 02/24/2011 4:51 AM
How do you know if your engine is a 230,235,250,292 when you have a straight six. I have all the numbers off the block and head but can't seem to find any sites where they can tell me what size engine I have. I have bought replacement parts for my motor and have been gambling with 230 size and seem to be doing pretty good so far. Any one have any suggestions?
1965 Chevy Straight Six Lover
Nando #723887 02/24/2011 5:28 AM
Try Inliners International for the casting numbers, which will get you close (there's some overlap on 230 and 250 blocks). The 235 and 292 will stand out as different. The 235 is a different engine design, no parts interhchange with the 230/250/292. That one was discontinued in the US in '62 (some '63 4x4s may have used them, though). The 292 has a few differences from the 230/250, mainly the feul pump is in a different location, and the block has a taller deck hight. Otherwise, they are very similar.
If you have the stamped serial number from the pad next to the distributor, you can post it here to get it decoded.
Bill Burmeister
LONGBOX55 #723892 02/24/2011 5:49 AM
FO602TA
Nando #724045 02/24/2011 7:43 PM
It's either a '65 230 or a '66 250. According to the code, it was built on June 2nd, you'll need to find a casting date to get the exact year.
Bill Burmeister
LONGBOX55 #724205 02/25/2011 4:16 AM
The codes I found where a E285.
Nando #724211 02/25/2011 4:30 AM
Ok, now we've got it! E285 is May 28th of '65, which matches up with a June 2nd asembly date. Your engine is a 230.
Bill Burmeister
LONGBOX55 #725222 02/28/2011 5:24 AM
Thank you very much.
