4 members (Maybellene, klhansen, 2 invisible), 87 guests, and 3 robots.
Topics128,211
Posts1,057,468
Members48,471
(Sorry if I got the numbers wrong.)
But I have a line on a '66 fleetside that is sitting in a field with 71,000 miles. (It actually still turns over with a blast of starter fluid.)
It's one of the smaller motors, and I am looking for parts...can I use the carb, exhaust header, intake manifold, and possibly steering?
My truck is a 1 ton C30 with a 292.
(Oh...and anyone want the motor to defray the cost of getting this thing home?)
Dave
1965 Chevy C-30 1-Ton
"Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching."
Riding in the Passing Lane
The manifolds & carb will fit. There is a little less beef in the center of the exhaust manifold but it will work fine. The carb has a smaller bore but will fit. You will loose a little power. The steering linkage is heavier on a 1 ton then a half ton.
1972 Chevy c10 Cheyenne Super
If the exhaust pipe is good on the 230/250 keep it also because your 292 exhaust pipe will not fit the 250. It is 2*1/2" on your 292 and smaller ( I believe 2") on the 250. Your 250 exhaust manifold has 2 studs for exhaust pipe and the 292 has 3 studs.
A 1965 Chevy C-60 2-Ton Flatbed
A 1953 Chevy 1/2-Ton
A 1949 Chevy Business Coupe
Hey Sable,
Come on up to Center Point. I have a 66 292 that's complete and a couple of clean fuel tanks with senders. What else you need?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
