4 members (Maybellene, klhansen, greenie-reddy, stlcardinalsguy), 64 guests, and 2 robots.
Topics128,034
Posts1,055,542
Members48,425
#723565 02/23/2011 5:09 AM
Anybody ever cut the top off a gas tank, clean and repair, and then solder it back together...perhaps with a stip over the joint?
Mine has a baffle loose and flopping around.
Gary
ggfossen #723569 02/23/2011 5:23 AM
what is the year. make model. all that fun stuff. is it in the cab or under the bed.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
GrandpasTruck #723571 02/23/2011 5:27 AM
If new is available, I'ld go that route,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
48bigtrucks #723579 02/23/2011 5:41 AM
Its not worth the trouble, I've done repairs years ago with brazing them back together, after all the cleaning and flushing to ensure you don't blow yourself up and burn down your shop.
Is it possible to just cut a hole where the baffles attach and repair it rather than cutting the entire tank in half?
The relatively cheap cost of new tanks really doesn't make this worthwhile, you could go through all the trouble just to have it crack a week or two down the road, puke gas all over your asphalt driveway, or garage floor, and end up buying a new one anyways, really just a PITA !!
1946 Chevy 1/2-Ton
More pix on Photobucket
Sometimes I forget where I left myself....
andy46 #723687 02/23/2011 6:44 PM
The truck is a '39 3/3 ton JD with the tank under the seat. New tanks are available, but all are in the $350 range. And I do agree that what seems "spendy" is indeed relative to problems down the road. Yes, I do understand the dangers of whacking on a gas tank, but I was curious if anyone had successfully fixed one. Hard to tell how long the baffle has been loose. I may have driven it that way for years. I suppose it could interfer with the gauge reading, but probably not anything else. The tank may be too rusted, anyway.
'Nuther question, though. It occurred to me that I may be able to put a tank between the frame rails, and then remote the fill to the original hole. Has anyone had experience with that??
Gary
ggfossen #723752 02/23/2011 10:48 PM
I had a gas tank with a leaky neck weld repaired about 8 years ago. Took it to a local radiator shop and they cleaned it and repaired it for about 30 bucks.
For the last few years I worked at a welding / fab shop that built large pressure vessels for oil field equipment. They did repairs all the time on oil and gas equipment. The vessels were steam cleaned internally and then an electronic "sniffer" is used to ensure there are no gas fumes remaining.
It can be done... Might want to check around?
Good luck!
Hot Rod John #723786 02/24/2011 12:46 AM
John,
OK, always good to know more about stuff. I had not heard of the steam cleaning...or thought about a radiator shop.
Gary
