BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
7 members (Fifty-Five First, Peggy M, Bill Hanlon, Guitplayer, cspecken, Lightholder's Dad, JW51),
549
robot. | Key: Admin,
Mod | | Forums66 Topics126,781 Posts1,039,301 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jan 2009 Posts: 42 Wrench Fetcher | Wrench Fetcher Joined: Jan 2009 Posts: 42 | I have a 1953-55 Corvette 235 engine with 1953 235 heads on it.It came from a truck that was in a garage fire.Its not frozen the pistons move when hand turned.Could this engine be saved?
| | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | Shop Shark Joined: Dec 2004 Posts: 1,897 | It depends how hot the fire got. Likely the block and crank can be saved. The engine needs to be torn down to inspect for damage. All gaskets and bearings need to be replaced anyway. | | | | Joined: Nov 2001 Posts: 1,516 'Bolter | 'Bolter Joined: Nov 2001 Posts: 1,516 | Im sure youve checked,but how do you know its a Corvettte engine? | | | | Joined: Jan 2009 Posts: 42 Wrench Fetcher | Wrench Fetcher Joined: Jan 2009 Posts: 42 | Becuse of the cast no#s 3835911.checking the no#s on Stove bolt.Its a 1953-1955 Corvette block.
| | | | Joined: Jan 2010 Posts: 32 New Guy | New Guy Joined: Jan 2010 Posts: 32 | If the nos. are for a 53 or 54 vette I would say the engine would be in high demand. Good bucks from a vette restorer. NCRS restorers are looking for correct numbers. Just an idea that might be turned into dollars. tom | | | | Joined: Jan 2001 Posts: 5,320 'Bolter | 'Bolter Joined: Jan 2001 Posts: 5,320 | You need to check the stamping next to the distributor to be sure it is Corvette. I don't have the info for 53 but 54 Corvette blocks would be stamped with a YG suffix.
See the USA in your vintage Chevrolet! My Blog | | | | Joined: Feb 2004 Posts: 28,675 Kettle Custodian (pot stirrer) | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 28,675 | Better check that casting number again- - - -3835911 is for a 1954 235 with a Powerglide transmission (possibly Vette), and it's also listed as a 1955 235, no mention of transmission. Your 33 at the beginning of the number is probably a 38. http://clubs.hemmings.com/clubsites/chevytalk/GMhistory/1916-57cast.html The stamped number on the pad behind the distributor will give you a better idea whether or not it's really a Corvette application. Jerry
| | | | Joined: Jan 2009 Posts: 42 Wrench Fetcher | Wrench Fetcher Joined: Jan 2009 Posts: 42 | Research Ive found on the 3835911 block. Is a 1954 with powerglide. And found on the 1954 Corvettes.Numbers on my are 0420333f54m.Other cast no# Con1 & C124
| | | | Joined: Jan 2001 Posts: 5,320 'Bolter | 'Bolter Joined: Jan 2001 Posts: 5,320 | The "M" suffix was used in 1/2 ton truck with auto trans in 54.
See the USA in your vintage Chevrolet! My Blog | | | | Joined: Apr 2006 Posts: 506 Shop Shark | Shop Shark Joined: Apr 2006 Posts: 506 | The "other cast no#" ...C124 is the casting date.
March 12, 1954
-Tom
1950 Chevy 3100 w/ 1956 235
