3 members (55shaker, JW51, Gdads51), 147 guests, and 1 robot.
Topics128,069
Posts1,055,896
Members48,428
#721607 02/17/2011 12:30 AM
Im planning on rewiring my 51 3100 here soon. Im not going all crazy with it just the norm like taillights and headlights and maybe an electric cooling fan. Would a 10 circuit fuse block be enough as far as circuits? ohwell
ohwell
Riding in the Passing Lane
Not if you plan on hooking up very many circuits & protecting them with fuses. A modern radio uses 2. 18 would be best or 12 if you double up some things.
1972 Chevy c10 Cheyenne Super
What George says. He's right on. You can get by with 12 fairly easy but you probably get more circuits for about the same money. You may also want to use the SMALL fuse block set up if you are putting it in a tight space. Also each wiring vendor offers different amounts of circuits so check around.
Thanx for the input fellas! Im also going with all LED lighting as far as light bulbs so that I dont put much of a strain on the electrical system smile
If you look around at the Painless Wiring fuse blocks, they come in various configurations with flashers and a fuse for pretty much everything. Just the fuse blocks aren't too expensive and they have labeled terminals on the mount so it's pretty hard to goof it up. Not that I didn't try grin
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
I bought from Kwikwire. Pretty easy and affordable. They come in many different fuse combinations. Kwikwire.com
Thom Masterson
Awesome! Thanx for the info fellow bolters!
1 Offline
Ive got a question about fuse boxes, ive got one from a 64 truck. would i need to upgrade it if all i have is the stock 53 things, lights, heater, ect. but i also would like to put in a modern stereo with just the stock behind the dash speaker, maybe one or two behind the seats as well.
