7 members (JW51, baldeagle, Oswald, Gdads51, Jay R, greenie-reddy, 1 invisible),
43
Mod | | | Forums66 Topics128,004 Posts1,055,247 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Hello All - I am in the process of re-wiring my 62, 235. I am getting no spark. With power "ON" the positive side of the coil shows 12 volts, the negative side shows nothing. Is my coil bad?
Thom Masterson
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Take the wire going to the distributor off at the neg side of the coil and repeat your test. You should read 12V on both sides of the coil. (If the points are in the closed position a good coil could possibly read what you are seeing)
Another way to test the coil is to remove the wire from the center of the distributor cap and hold it (with insulated pliers or gloves) about 1/4" away from a good ground. Turn the key on and manually open and close the points, you should see a good spark jumping to ground.
| | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | When I tested the coil, the wire from the negative side was disconnected from the distributor.
Thom Masterson
| | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | I got her started. New coil, points and condenser. Runs great! One problem...when I turn the truck off, it makes an ugly grinding sound that sounds like the starter. Any suggestions?
Thom Masterson
| | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Anyone have any ideas? See post above. Thanks!
Thom Masterson
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I'm assuming this is a key-start truck? Possibly a problem in the ignition switch that's sending voltage to the solenoid during turn-off. You could check it with a trouble light on the starter solenoid terminal that comes from the switch, if you see a momentary light during shut-down, you've got a problem in the switch or something is wired wrong. | | |
