8 members (Bill Hanlon, Jon G, 55shaker, Otto Skorzeny, HandyAndy, UtahYork, DadsFirstPickup, Hotrod Lincoln), 78 guests, and 3 robots.
Topics128,036
Posts1,055,448
Members48,422
#721506 02/16/2011 4:50 PM
Hello All -
I am in the process of re-wiring my 62, 235. I am getting no spark. With power "ON" the positive side of the coil shows 12 volts, the negative side shows nothing. Is my coil bad?
Thom Masterson
Take the wire going to the distributor off at the neg side of the coil and repeat your test. You should read 12V on both sides of the coil. (If the points are in the closed position a good coil could possibly read what you are seeing)
Another way to test the coil is to remove the wire from the center of the distributor cap and hold it (with insulated pliers or gloves) about 1/4" away from a good ground. Turn the key on and manually open and close the points, you should see a good spark jumping to ground.
waldo53 #721543 02/16/2011 6:54 PM
When I tested the coil, the wire from the negative side was disconnected from the distributor.
Thom Masterson
I got her started. New coil, points and condenser. Runs great!
One problem...when I turn the truck off, it makes an ugly grinding sound that sounds like the starter. Any suggestions?
Thom Masterson
Anyone have any ideas? See post above.
Thanks!
Thom Masterson
I'm assuming this is a key-start truck? Possibly a problem in the ignition switch that's sending voltage to the solenoid during turn-off. You could check it with a trouble light on the starter solenoid terminal that comes from the switch, if you see a momentary light during shut-down, you've got a problem in the switch or something is wired wrong.
