1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#719258 02/08/2011 3:07 PM
Does anybody know a good way to remove a froze in screw? I got three that are holding my door panels on, and I absolutely cannot get them to break loose. I've virtually soaked them in lubricants, tried heating them, and tried tapping them with a hammer. I'd rather not drill them out, but it's seeming like I have little choice.
1956 Chevrolet 3100 - "WonderTruck"
"I used to be 'With It.' Then they changed what 'It' was. Now what I'm 'With' isn't 'It,' and what is 'It,' seems wierd and scary to me."
There are a couple tips in the Tech Tips section.
Brad Allen #719391 02/08/2011 10:29 PM
How hot did you get them. I usually heat until I see dull red, then let cool to room temp and try them. Usually works for me.
If they are actually screws, a hand held impact hammer has worked well for me after the heat and oil penetrant has been applied. This devise has a ratcheting action that moves as you strike the end with a ball peen hammer.
Huck #721238 02/15/2011 3:22 PM
They're actually screws. At least the other 10 that were holding the door panels on were.
If ya cannot get em loose after using an impact driver ...I would drill the heads off remove the panel and go after the remaining part of each screw with PB Blaster,some heat and vise grips.
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #721265 02/15/2011 4:43 PM
I've used valve lapping compound dabbed into the head of the screw to provide a good grip. You don't want to strip them. Then hard pressure with your driver and turning with a visegrip attached to the screwdriver. Slow and easy wins the race!!
gotgasd #721284 02/15/2011 6:36 PM
best with corroded screws and bolts to first tighten one lick, which will frequently free them up
squeeze #734820 03/31/2011 2:25 AM
Get'm hot, a little red, then let'm cool down. Then they will come out. Don
