Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (KingG, Joe H, Lightholder's Dad), 42 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
#720758 02/13/2011 9:36 PM
Just bought a new windshield for my 59 and it does not want to seat right. New rubber from Steele Rubber Co. I'm using lube on the gasket and a curled hook tool to pull the flange in. The window seems to be set right except in the lower corners of the wrap around. This is giving me fits. Any and all help appreciated. Thanks, Mike
This glass install has been covered here countless times, and the common thread centers around the difficulty or the impossibility of making the install without massive uses of profanity.
The usual solution seems to be to call a glass shop and let them do what they do well.
~Jim
as BIG CHEVY says, a professional can be helpful, at least if the new glass gets broken it's not your fault wink
the TF glass can be very frustrating and no doubt it was at the factory, but note that there are checking procedures in the shop manual to see if the glass is the right shape before attempting installation - it could well be that the one you got just won't fit well on your particular truck, the Steele rubber should be A-1
note also that in the manual there's instructions on using a cord in the rubber slot that may work better than your hook , and the inner 'flap' piece is usually a problem to get laying well
squeeze #720956 02/14/2011 3:22 PM
That is just because I wasn't home yesterday to help you wink
gazim #720965 02/14/2011 3:39 PM
You need to wait until gaz gets home from church to tackle such difficult things
Dennis
Yeah! Gaz will help you through the hard stuff. Don't rush into these things you might break a fingernail. lol
~Jim
Got er did! No help from Gazim. This was a bear.
good on ya! perseverance wins the day wink
squeeze #721213 02/15/2011 8:28 AM
Well done, I know the dog leg TF screens can be tricky, you stuck at it and got 'er done!
More pix on Flickr.
So did you do it alone? Please share the tricks how to do it.
Did you use any kind of sealer, like the manual says? I've never done one but soon will.
I hired an installer who came to my place, and helped him as this at the very least is a two man job. 75.00 well spent, more than resonable I thought. He even helped with the back glass. Used the rope method and soapy water and alot of open hand slapping to the glass, and a little cussing. As I now know, these TF windshields are a bear to install, but man that new glass sure looks nice.
He didn't do it alone for sure. I remember we pulled the rope from the inside,not outside. We went out for dinner to celebrate.
gazim #721325 02/15/2011 10:16 PM
Hey Gazim, ??????? You wasn't there.
