1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
Page 28 of 177 1 2 … 26 27 28 29 30 … 176 177
took the cover off it and drove it.It was a good day
Yesterday I drove from Chicago to Columbus Ohio and back. Dropped off my torque tube and differential to have it split and then an overdrive installed in the torque tube. I'll report on the saga in the tranny form.
Dave, the pics, where are the pics? pix
~Jim
I put my rebuilt 4 speed back in and finished putting the floor etc. back together. I also put a little bend into the shifter to clear my knee when it is in reverse.
1951 1 Ton Completed
Z
Z Offline
Removed the tailgate. Removed most of the interior pieces and found swiss cheese. Cleaned up the inside of all pieces of rust and dirt. Removed the seat and frame. Figured out engine is the original engine from 52. 90k miles on it. Removed wheels and tires they are shot to hell. Start list of parts needed. Got depressed. LOL
52 Chevy 1/2 ton - work in progress
65 Mustang coupe - work not in progress smile
67 Mustang GT convertibile
67 Camaro RS/SS
We are now even with fords and chevys. smile
Now i need a mopar. Hahahahahahahahaha
Mocked up my newly sandblasted and painted parts. Still gotta paint the block
pic
http://s783.photobucket.com/albums/...%20pickup%20project/?albumview=slideshow
Firewall mounted brake pedal assembly. Then installed the carpeting and the headliner. Hopefully I’ll get to the steering column this week.
More pictures to follow…………………
’53 5 window
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Mounted the new fuse block on the inner firewall, and started pulling wires tonight. What a mess of spaghetti.
Getting closer to being ready to fire it back up for the first time in many months.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
Solder all those joints Farmer. BTW, got a camera? pix
~Jim
Took mine out for some exercise yesterday. It was sunny and 16 degrees. Today, it's a freaqking snow bonanza. The truck won't be seeing pavement for awhile.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
This is a good week for the NAPCO boys.
http://www.napco4x4.org/
~Jim
scraped some dirt off of the frame.
*UNDER CONSTRUCTION*
1953 Chevrolet 3100 1/2 ton-previously abandoned resto.
My Project Bolt
I hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
Leo Offline
Moderator
Moderator
Got the running boards on, things lined up fairly well. Busy with the hood strip and front emblem.
49 1-ton Put in the two piece windshield. Wish the corners and back windows were that easy.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
ceg Offline
Me too!
Restoring 1950, 5 window, 1/2 ton, in family since new. Never done one before.
Just looked at it, its too cold under the carport!
not a lot just rattlecan restoring the frame after cleaning with the sandblaster yesterday no snow or rain here in he desert
just scored a brand new offenhauser intake with linkage and beehive oil filter with lines and 2 mini chrome air filters all for $275 bucks!! guy was selling cause they wouldnt fit his 250 in his wifes 57 chevy bel air.
Finally got a good windshield regulator assembled and ready to install. Had to cut a new worm and graft it in to the old crank spindle, made a new brass locator for the spindle, and had to put a bushing in one end of the housing. Took the horn and bracket assembly off so I can fab up a new bracket. You know what they say - "it's the little things".
I walked by it and apologized for not being able to take it out for a run. 8" of snow and ice on the roads. it gets around great but if something happens i would have a big fight with insurance company. oh well.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Yesterday I blasted the lower radiator apron. A fellow bolter had one that was much better than the one I had. I don't usually do anything on sunday but I did sneak out to the shop long enough to spray some self etching primer on it!! Tomorrow it gets paint. I had originally planned to use POR15 but decided to keep it for another project.
Alvin:
Your pics in Potobucket don't go past group 1. Where are the latest?
~Jim
Mounted the steering column and made custom linkage to connect it to the gear box. Working on the throttle cable and kick down cables now.
’53 5 window
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
FINALY, after 4+ years the engine fired up and idled smoothly at 2000 rpm for a little over twenty minutes,( I wanted to break it in) at which time the power steering pump began to smoke and scream. It seems the front seal on the pump began to leak until the fluid was gone and the bearings began to squeal. I'll put another pump on this weekend. I wonder if sitting up for 4 years dried out the seal.
I filmed the experience with my Sony digital VCR camera and if I can get the film transferred to a DVD I'll post it on You Tube and post the link here. It's pretty funny when it all hit the fan and the smoke blew out around us.
~Jim
I'll bet that was exciting.
I got the electric fuel pump change-over done on my burb. I dummied out the mechanical pump and have fuel running through the settlement bowl.
I put the sway bar on the front of my '57,if i have time this weekend,i'll do the rear.Got power to the garage for my new welder,looking forward to learning.
went to the harwdare store, picked up a few sticks for a project.
...pic..click..
Got a few thumbs up.
Just doing what it was built for......
Here's another..... thumbs_up
More pix on Flickr.
Installed my horn bracket that I altered to properly locate the horns (they were right against the radiator). Looks a lot better now. Also tried to figger out why cowl vent will not stay closed. I think the foam gasket has something to with that - not sure yet. Anyone ever had an issue like that?
...pic..click..
Good looking 2 X 4s Dad
~Jim
Loose the foam rubber and get a seal from Steel Rubber.
http://www.steelerubber.com/
That might not solve the closing problem but it will improve the seal.
~Jim
Best part was when I got home and had the little guy helped me unload
...pic...
Have not taken him for his first ride yet.
Got lap belts but want to bolt the center strap on his car seat somehow.
Not like the good old days,
I remember my Dad driving me around in this very truck when I was a kid, standing on the floor of the cab.
Cigarette lighter turning cheery red
My sister almost fell out one time making a left turn. She remembers that vividly
That was fun.
What else I got done today
Started putting some tools under the seat, now that Im driving it more.
I also need to figure what Kind of jack to carry
Thanks again
DAD, how did you get a tag with "DADS50" and the year 1950?
~Jim
That's a novelty plate on the front, ordered it from .licenseplates.tv DMV plate on rear.
The front plate is correct for year and state. Put my number on it
Z
Z Offline
DADS50,My 51 3/4ton looks like the twin to your 501/2ton.I have been trying to post pictures,from PhotoBucket on here,can not get them to work? Good Looking Truck,I like the background. The last time,I drove across that way,was in 1974,right after I got out of the Air Force. I was driving truck,cross country teaming with my brother.
My truck was originally red, when my Dad bought it in 73 he had it painted dark blue. Ill roll with this light blue for a while
I would like to see your pic's I had a hard time figuring out how to link photos also. Had to get the old lady to show me.
Basically when you’re in the reply screen use the planet button next to the smiley face button. When I click the planet button a window opens up. I copy and paste the address bar to my pic there.
PM me if your still having problems,
Now back on topic,
What did I get done today…I realized I need a louder clicker for the signals, steering wheel blocks the blinker light.
Good Luck
Z
Z Offline
Trying to post pictures.
Pulled a 261 runner from a '55 2-ton - purchased from a fellow stovebolter! - and brought her home yesterday. Was surprised and happy to discover how she looked under the valve cover:
https://picasaweb.google.com/lh/photo/Jkt1Bxh2i1l1--cMTHQnoIS57yeOEu0D66Y1HCcr6ZM?feat=directlink
https://picasaweb.google.com/lh/photo/2ysSZj8zsIryGN0W8M1UM4S57yeOEu0D66Y1HCcr6ZM?feat=directlink
I'm a happy camper today. Can't wait to drop her into my '50 1/2-ton! grin
Hope its been oiling. It looks petty dry.
~Jim
got my 74 camaro rear end bolted up on my 51 3100 grin
