Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
8 members (Otto Skorzeny, Drew54, Bristol's Tree S, klhansen, jay d, 78buckshot, 55shaker, Perro), 99 guests, and 2 robots.
Topics128,281
Posts1,058,488
Members48,490
#715487 01/26/2011 9:46 PM
Hello all, I need to replace my Radiator in my 46 Chevy 1.5 Ton. I know it's a 4 core. Can a 3 core be used? Can a Radiator from a 39-40 be used? If anyone knows what I can use or what is compatible please let me know.
Apprentice
Apprentice
First off what depends on motor size if still original 216 3 will work. Afco makes a replacement also try Jim Carter Trucks at oldchevytrucks.com. Hope it helps
EMS is my life. But I have found my TRUE PASSION OLD TRUCKS...
It's a 235 and has a 4 core radiator. I've already tried Carters.
If you are saving pennies... I was just quoted $860 (new zealand) to recore my '47 1.5 ton. I could probably hunt around for a better deal.
Not sure if you guys had Toyota Hiluxs over there? The core of the hilux radiator is 25mm higher and 30mm wider. I think its three core (50mm thick). The pipes are in the wrong place. I can change them no problem.
It will be a tight fit (about 5mm to spare) in the frame but I am certain it will do-
I have bought a good secondhand one for $120 and it will be here in a week, I will let you know how useful it is.
The radiator shop guys said that the newer cores cool a lot better than the originals, three core would do in our climate.
But they quoted for a 4 core.
'47 Canadian RHD 1.5 ton truck
The radiator arrived.
The seller measured it wrong- its about 10mm wider than they said which means it isnt easy to fit.
So dont consider one of these.
The radiator I got is brand new, I will narrow it by three cores and it will be fine- but I will have a wary eye on the temperature guage.
