3 members (Donf, Shof, Peggy M),
131
Mod | | | Forums66 Topics128,281 Posts1,058,488 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Hello all, I need to replace my Radiator in my 46 Chevy 1.5 Ton. I know it's a 4 core. Can a 3 core be used? Can a Radiator from a 39-40 be used? If anyone knows what I can use or what is compatible please let me know. Thanks | | | | | Joined: Dec 2008 Posts: 23 Apprentice | | Apprentice Joined: Dec 2008 Posts: 23 | First off what depends on motor size if still original 216 3 will work. Afco makes a replacement also try Jim Carter Trucks at oldchevytrucks.com. Hope it helps
EMS is my life. But I have found my TRUE PASSION OLD TRUCKS...
| | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | It's a 235 and has a 4 core radiator. I've already tried Carters. | | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | If you are saving pennies... I was just quoted $860 (new zealand) to recore my '47 1.5 ton. I could probably hunt around for a better deal.
Not sure if you guys had Toyota Hiluxs over there? The core of the hilux radiator is 25mm higher and 30mm wider. I think its three core (50mm thick). The pipes are in the wrong place. I can change them no problem. It will be a tight fit (about 5mm to spare) in the frame but I am certain it will do- I have bought a good secondhand one for $120 and it will be here in a week, I will let you know how useful it is. The radiator shop guys said that the newer cores cool a lot better than the originals, three core would do in our climate. But they quoted for a 4 core.
'47 Canadian RHD 1.5 ton truck
| | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | The radiator arrived. The seller measured it wrong- its about 10mm wider than they said which means it isnt easy to fit. So dont consider one of these. The radiator I got is brand new, I will narrow it by three cores and it will be fine- but I will have a wary eye on the temperature guage.
