4 members (2-Ton, Phak1, KEVINSKI, dunfire), 110 guests, and 3 robots.
Topics128,196
Posts1,057,395
Members48,471
So Im trying to install the weather stripping on a 1950 Suburban and i dont recall how the weather strip goes on. I found a page on here a few weeks back but cant find it now. I believe im going crazy. any pics would be helpful!
I tried searching but couldnt find anything.....
thanks
Marc
Marc
took me two attempts, First seal I purchased didn’t fit well
Check out this pic ...pic..click
The seal on the left in that pic was to thick, the one on the right has a sharper v cut and fit better.
here is how I glued it on the door..click...
...pic...click...
another cross section pic..click
pic of the sides I glued
Alans web site..click
more reading
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=364611&page=1
After all that, I’m not 100% sure I installed it correctly, I wouldn’t be surprised if an experienced bolter would look at my pics and say..hey that’s wrong.
My doors close nice and I have a good seal.
look at my pic's as reference only. The seal kit I ended up using came from TUCKERS truck in las vegas.
Good luck
Thanks for the info. that was the site i was looking for. Still is a bit confusing but Im sure Ive got it. you would think there would be a page from the manufacturer like steele that would be much better then the one they offer. to vague in my opinion.
If anyone has any more info or pics of the seals for the rear clam shell doors or other door pics please post them. any help on wrapping up this customers project would be much appreciated!
Thanks in advance!
Marc
ok so im just gonna say that weather stripping the doors while they are on is a Pain in the [censored]! not to mention irritating when you install the wrong size door weather strip the first time!!!
lol
I am not seeing what weatherstrip adhesive you are using
This is a shot of my 1952 panel door. Does this help??? I am just holding another piece up to the already installed just to show how it goes. Its had to tell someone after its already on the door. I used 3M black Weatherstipping.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0216.jpg
Leo Offline
Moderator
Moderator
I just did mine a few weeks ago. I took the doors off the cab to glue it on, but I left the rear doors on, no problem. I used Alan's tech tip, helped a lot. I also used the black 3M adhesive, mine was in a tube.
