2 members (Peggy M, MNSmith),
240
Mod | | | Forums66 Topics128,282 Posts1,058,495 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 8 New Guy | | New Guy Joined: Jan 2011 Posts: 8 | Does anyone know what color the bench seat frame on a 53 5 window 3100 is suppose to be? The exterior color is Mariner Blue 1953. Any help would be GREATLY Appreciated as well as upholstery color that would probably have gone with this exterior color. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Frame should be same color as interior (semi-flat charcoal enamel sight metallic long a topic of discussion and debate). Seat is usually dark brown as shown. Several vendors sell the kits and the paint if you search the formula has been posted previously. http://good-times.webshots.com/photo/2442282910102454676pfKDXm
| | | | | Joined: Jan 2011 Posts: 8 New Guy | | New Guy Joined: Jan 2011 Posts: 8 | Thanks! I'm learning more about these trucks everyday. I'll check out the links tonight. I thought the interior body was painted the same as exterior. Was the charcoal enamel a standard color for the interior no matter what the exterior color was? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | 1953 is a unique color and there is debate about what is correct and what the actual color is and what variations there may be. Interior color was always unique from the exterior truck color up until the end of the A-D years when other deluxe colors became available in 1954/55. Here is where you can get a little more clarification (vendor info). http://secure.oldchevytrucks.com/Interior-Paint/products/621/If you look at pictures of trucks you will see many where interior/exterior color is the same (my own truck is like this). That is most likely personal preference being demonstrated not factory colors.
