1 members (Thomaslb),
138
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 5 New Guy | | New Guy Joined: Jan 2011 Posts: 5 | How can a person determine the displacement of the pontiac engines used 55-59? Thanks Russ | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If they are from a GMC truck there is a serial number stamped into the block on the right side near the oil pan. The first 3 numbers are the displacement of the engine. I don't know if car engines have this or not. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | how about by the year and or casting numbers? 1955 287 1956 316 1957 347 1958 370 1959 389
1958 and 1959 gmc engines were debored pontiac 370 and 389 to come up with 336 inches. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | how does one debore an engine? ron | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | One doesn't. The factory does. I suppose if you wanted a smaller cubic inch motor, you could install sleeves in the cylinder bores. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I would imagine that the 59 version would have had a little torque due to to longer stroke and the smaller bore. I was just teasing about the deboring(just sounds funny) ron | | |
